ArcGISDynamicMapServiceLayer showing white pixels as transparent even though black pixels are supposed to be background
658
05-29-2017 09:11 AM
IsaacBoates
We are visualizing a tiff image in our web map.  We have set the layer properties to say that black pixels are to be treated as background, and that they should be displayed as transparent.  Visualizing it in ArcGIS Desktop confirms that this is working properly.  However, as soon as the layer is published and the layer is put into a ArcGISDynamicMapServiceLayer, the white pixels seem to become transparent.  We cannot seem to identify the cause of this problem.
This is the code (SETTLE_VP_ORTHOPHOTO is a variable storing the rest endpoint for the layer.):
var VP_ortho = new ArcGISDynamicMapServiceLayer(SETTLE_VP_ORTHOPHOTO ,{
    visible: false
This is the service layer definition:
Layer: mos_VP_2.tif (ID: 0)
Display Field:
Type: Raster Layer
Geometry Type: null
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: true
MaxRecordCount: 0
Supported Query Formats: JSON, AMF, geoJSON
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: false
Supports Statistics: false
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Use Standardized Queries: true
Extent:
      XMin: 2065234.8595104713
      YMin: 6195018.263458403
      XMax: 2068324.6069604708
      YMax: 6199050.734858402
      Spatial Reference: 102100  (3857)
Drawing Info:
    N/A
Advanced Query Capabilities:
      Supports OrderBy: false
      Supports Distinct: false
      Supports Pagination: false
      Supports TrueCurve: false
      Supports Returning Query Extent: true
      Supports Query With Distance: true
      Supports Sql Expression: false
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeNone
Type ID Field: null
Fields: None
