ARCVIEW
1090
11
05-18-2017 01:59 AM
francescarusso
New Contributor III
HI,
I have been asked to provide some data that can be read in GIS (ARCVIEW). Is it not reading a regular .gdb data?
If not, any suggestion? What I have is just an .gdb. Can I convert the data in some how?
Many thanks,
F
JayantaPoddar
MVP Esteemed Contributor
If you have ArcMap (Standard/Advanced license), you could export the data from File Geodatabase (*.gdb) to shapefiles. ArcView should be able to read shapefiles.
Think Location
francescarusso
New Contributor III
Thanks. do you know what about the raster I have in my .gdb?How can I export?
Cheers
F
JayantaPoddar
Open the respective image in ArcMap > Right-click the layer > Export.
Save the raster in a basic folder (not in a geodatabase) in either *.tif or *.img format.
FAQ: What are all the file extensions related to ArcView?
Exporting a raster in ArcMap
Think Location
francescarusso
New Contributor III
Thanks. I have tried to follow the instruction in the provided link, but when  I try to export, it seems the only way it saves it is .dbf so it doesn't make the job
F
JayantaPoddar
A DBF option will come when you are saving a table. Are you sure you are exporting the Raster data? Could you provide screenshots?
Think Location
francescarusso
New Contributor III
So it is a Side scan sonar raster. Please see below
JayantaPoddar
What version of ArcMap are you using? I am getting the following options of saving the Raster in following formats when my output location is a basic folder. I am using ArcMap 10.1.
Raster Type
Think Location
JayantaPoddar
Try converting Raster Catalog to Raster Dataset. Save it with .tif or .img extension.
Think Location
francescarusso
New Contributor III
ArcMap 10.2. How bizarre is this?
