AnsweredAssumed Answered
Prevent rotation of symbols in Map service export request
Question asked by venarinz on May 17, 2017
Latest reply on Dec 22, 2018 by NicolasGIS
I have a system (ArcGIS Server 10.5, ArcGIS JavaScript 4.3) whereby I'm allowing the user to rotate the map, and then request a PDF output of the map.
I need to ensure that the symbology is always oriented upwards - i.e. not rotated with the dataframe.
I've updated the following registry key, and this helps ensure that when viewed in the MXD, and created as PDF output, the icons are oriented correctly, i.e. towards top of page/screen.
HKEY_USERS\<USERID>\Software\ESRI\Server10.5\Symbology\Settings\RotateWithTransform
However, in my web client, when my app does a MapServer export with rotation, the symbology is always oriented North - e.g.:
Sample MapServer export
Is this normal behaviour? Labels are oriented correctly - see further example, again rotated 15 degrees:
Is there something I can do to ensure that the icons are not rotated?
Cheers,
Leigh
Outcomes
