Label positioning in ArcGIS Pro.
890
05-14-2017 01:54 PM
CamillaPayne
Wondering what the best way is to position labelling on a polygon so that it isn't displayed outside on the polygon boundary. Have attempted un-ticking the 'may place label outside polygon boundary' function in the labelling pane however doesn't seem to make a difference. Have tried reducing the file size.
Thanks.
Tags (1)
DanPatterson_Retired
Are you labelling on the center? or off to oneside of the label point?
CamillaPayne
Labelling on the center.
Ok, then there is basic labelling and labelling with the Maplex label engine and if go to that link you will see two others beneath which deal with the basic and maplex engine.  Short of posting explicitly what you are doing with a screen grab, you might want to rule out some of the other options.  The reasons could be varied.
JayantaPoddar
MVP Esteemed Contributor
Check what happens if you use Only place label inside polygon option. Set polygon label placement properties—ArcGIS Pro | ArcGIS Desktop
Think Location
