GeoEnrichment tool in Pro keeps failing
809
05-10-2017 08:54 AM
JenniferRogerson
When using the GeoEnrichment tool in Pro, it keeps failing because "Unable to access GeoEnrichment server." Why does this keep happening?
George_Thompson
Esri Frequent Contributor
Are you logged into ArcGIS Online within the Pro session?
Enrich Layer—Help | ArcGIS Desktop
Geoprocessing tools that use credits—Appendices | ArcGIS Desktop
You need to have credits available to you to use.
Can you add the base maps in Pro with no issues?
--- George T.
JenniferRogerson
HI…Yes, I am logged in. And have more than enough credits to use (burned thru more than 100 this morning trying to use the tool, but not connecting)…and yes. I can add the base maps also.
Jennifer Rogerson, HBA, CPT | GIS/Planning Technician
County of Middlesex
399 Ridout St N | London ON N6A 2P1
T 519-434-7321 x.2348 | www.middlesex.ca
George_Thompson
I am not sure the reason, I would make sure that you are at the latest release, 1.4.1.
Did this work in the past?
You may need to open a support case to further investigate.
--- George T.
JenniferRogerson
Thanks. Good point about new release. We haven’t updated yet. We have only just started using the GeoEnrichment…only went to Pro because Online was giving me issues. I went back to using Online…still getting the error messages, but am at least getting the results an data I need.
Thanks for your help. ☺
County of Middlesex
