pulldata for calculations
680
05-09-2017 11:25 AM
by Anonymous User
Not applicable
Hi all,
Is it possible in survey123 to pull data (for example, I already have the height of the cylinder) add it into some of my calculations? Is there a way to do that?
Alex
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
Yes it is. The key consideration is 'where is the data coming from'?  You can either pre-fill information into a field using the App URL schema: https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche..., or have a CSV file accompany the survey with lookup information being retrieved by the pulldata function: https://community.esri.com/groups/survey123/blog/2016/10/27/the-pulldata-function-access-external-da...
