Splitting Route into Point at Intervals of M
987
05-08-2017 11:14 PM
ThomasBaxter
Is there a way to split a route into points at a set interval of M?
I need to generate a series of points alone a route at a defined interval - I can do this with a distance interval, but I'd like to be able to use our Measure data to determine where the points are located
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
LeoLadefian5
Occasional Contributor II
Adding route events assumes you have a point file as events.  This tool adds the points to your route as events.
TedKowal
Occasional Contributor III
I am assuming that you do not have access to geo-wizards or other custom tools....  One old fashion way was to semi-manually create the points from event mapping against the LRS (Routes).
Below pictured is a modern guide on how to use an excel spreadsheet to calculate the interval and "Events" needed to map the points.  It should be fairly self explanatory.
Points along a Route at a defined Interval
