How to display a local shapeFile format file?
1276
05-08-2017 10:18 PM
YanQiJiao
I have a file with '.shp' suffix, I have read the documentation, but I haven't find how to do it.
Tags (1)
BaocaiZhang1
you can use  shapeLib to read the file
Shapefile C Library
DiveshGoyal
We currently do not support directly reading shapefile from disk. This is planned for a future version.
In the meantime you can upload the shapefile to ArcGIS Online or Portal and create a webmap from it. Then that webmap can be displayed easily using the runtime.
YanQiJiao
Thank you very much!  I have resolve this problem, I take the shapeFile above the baseMap in ArcGis Pro, then I used tool named "creat map tiled package" ,it can change the map to ".tpk" format. It is simple to display it on iPhone.
I have another request, I only find the iOS runTime SDK samples that code with Swift language, can you provide another coded with OC language?
YueWu1
by Esri Regular Contributor
Hi YanQi Jiao,
Here is the Objectic-C version of sample code to load the .tpk file:
arcgis-runtime-samples-ios/LocalTiledLayerSample/objective-c at 10.2.5-to-quartz · Esri/arcgis-runti...
Hope this can help
