AnsweredAssumed Answered
heat map
Question asked by shafey_i2IMS on May 3, 2017
Hi there,
I try to create an app with ArcGIS runtime SDK for .net 10.2.7. I almost finish but stuck on the Heat map renderer, I have thousands of points in a Spatial database , need to create a heat map and add as a separate layer in my app.
My question is :
  1. Is there any heat map renderer is available in ArcGIS runtime SDK for .net?
  1. Are there any open source alternatives available if it’s not present in ArcGIS runtime SDK for .net?
  1. If above both case is failed , then my idea is to publish a geo-processing tool in ArcGIS server and add a separate layer return result form that geo-processing tool , Is there any one implements this before?
With kind regards,
Abdul Shafey
Outcomes
