Story Map won't load services located on my server, only located in the cloud
438
05-03-2017 07:50 AM
ChrisDiDio
So I created a Story map and it worked fine for a couple of weeks. Then all of a sudden it wouldn't load any of the services that were published on my server. It only works with services that reside in the cloud. Anyone else have this problem?
AdrianWelsh
MVP Honored Contributor
Hi Chris,
Can you view the regular web map that the story map is based off of? Or are the services missing there too?
OwenGeo
Esri Notable Contributor
Hi Chris -- This might happen if you are accessing the story map over https and the URLs you are using to access the services are http. Are you able to check that and/or post a link to your story here so we can investigate?
Owen Evans
