can't interact with feature table widget, api version 3.20
827
6
05-02-2017 02:50 PM
KirstenLawrence
New Contributor III
I developed a widget that loads the esri feature table widget in an app using api version 3.17. When I change my api reference in the app to 3.20, I can no longer interact with the feature table - rows are not selectable, nothing is clickable, though the feature table does load as it should. Any ideas out there?
RobertScheitlin__GISP
Kirsten,
   Have you checked the browsers web console?
KirstenLawrence
New Contributor III
Yes it doesn't give an errors
Kirsten,
  Can you share your code for debugging?
KirstenLawrence
New Contributor III
Here is a link to the code for the widget with a highlight on where the feature table is created. Thanks for looking
LayerFilter.js · GitHub
Hmm.. I'm not seeing the issue.
deleted-user-iPdcWUgWcsoy
New Contributor III
I've got the same problem. I've tried to add the FeatureTable to different dom nodes or layout widgets and I still get this problem. Now my workaround is to delete the "_trailingPaneNode" of this widget.
var myFeatureTable = new FeatureTable({
    featureLayer : featureLayer,
    map : this.map,
    syncSelection : true,
    outFields: ["*"]
}).placeAt(this.domNode);
myFeatureTable._trailingPaneNode.destroy();
Somehow there is a problem with some style or something in this node. After I delete this node I can interact with the widget.
