TSC and 4x: Basemap Gallery in a Dijit Dialog?
631
05-02-2017 09:11 AM
DirkVandervoort
Occasional Contributor II
Greetings fellow travelers!
I'm trying write a custom widget that puts a Basemap Gallery in a Dijit Dialog. My debugger tells me the Basemap Gallery is fully hydrated and available, yet my UI tells me otherwise:
In HTML:
var basemapGalleryInADialog = new BasemapGalleryInADialog({
 view:view
 view.ui.add(basemapGalleryInADialog, "top-left");
The TypeScript widget class:
/// <amd-dependency path="esri/core/tsSupport/declareExtendsHelper" name="__extends" />
/// <amd-dependency path="esri/core/tsSupport/decorateHelper" name="__decorate" />
import {aliasOf, subclass, property, declared} from "esri/core/accessorSupport/decorators";
import {accessibleHandler, jsxFactory, renderable, vmEvent} from "esri/widgets/support/widget";
import Widget = require("esri/widgets/Widget");
import MapView = require("esri/views/MapView");
import SceneView = require("esri/views/SceneView");
import BasemapGallery = require("esri/widgets/BasemapGallery");
import Dialog = require("dijit/Dialog");
const CSS = {
 base: "esri-home esri-widget-button esri-widget",
 text: "esri-icon-font-fallback-text",
 basemapIcon: "esri-icon esri-icon-basemap",
 loadingIcon: "esri-icon-loading-indicator",
 rotatingIcon: "esri-rotating",
 disabled: "esri-disabled"
@subclass("esri.widgets.Widget")
class BasemapGalleryInADialog extends declared(Widget) {
 // Lifecycle
 * @constructor
 * @alias module:esri/widgets/Widget
 * @extends module:esri/widgets/Widget
 * @param {Object} [properties] - See the [properties](#properties-summary) for a list of all the properties
 * that may be passed into the constructor.
 constructor(params?: any) {
 super();
 // Properties
 // view
 * A reference to the {@link module:esri/views/MapView} or {@link module:esri/views/SceneView}. Set this to link the widget to a specific view.
 * @type {module:esri/views/MapView | module:esri/views/SceneView}
 * @name view
 * @instance
 @property()
 @renderable()
 view: MapView | SceneView = null;
 // Public Methods
 go() {
 var basemapGallery = new BasemapGallery({
 view: this.view
 var myDialog = new Dialog({
 title: "Basemap Gallery",
 content: basemapGallery
 myDialog.show();
 render() {
 return (
 <div bind={this} class={CSS.base}role="button" tabIndex={0} onclick={this._go} onkeydown={this._go}>
 <span aria-hidden="true" class={CSS.basemapIcon} title="Basemap Gallery" />
 <span class={CSS.text}>Basemap Gallery</span>
 </div>
 // Private Methods
 @accessibleHandler()
 private _go() {
 this.go();
export = BasemapGalleryInADialog;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I'm just messing around with the UX and I thought I'd open this pattern up for discussion, help, etc. TIA
KellyHutchins
Esri Frequent Contributor
I setup a quick test and it worked for me once I added a container for the basemap gallery.  Here's the code I modified from  your example.
            view: this.view,
            container: document.createElement("div")
        myDialog.show();
KellyHutchins
            view: this.view,
        myDialog.show();
DirkVandervoort
BOOM. Thanks Kelly!
