I have 2 questions.
1- I'm working on our gas coverage system. Our techs will be accessing this data in the field via a mobile device so there are features they will need to see such as dimensions and line work with attributes.
I have many features in my TOC but only want to send a few of them to my AGOL account..
Do I have to remove ALL the features I don't want brought over to my online account or is there a way to select only those features?
2- Is there a way to bring dimension feature classes from ArcMap over to AGOL?
Hi Corey,
For question 1, you will need to remove the layers you do not want published. Or, you could publish all of the layers and use the following tool to register each layer as an individual item in ArcGIS Online:
Add Individual Layers within ArcGIS Server Services as Items to ArcGIS Online/Portal
You can then build your web map with only the layers you want.
