Struggling with Survey123.
868
7
04-27-2017 04:18 PM
MichaelJabot
New Contributor III
I am struggling with Survey123. I have created the survey with the web creation tool. When I try to share with 'Everyone" it also selects the "Within ORG" and I can not uncheck that box which forces the person to have to be a member of the ORG. Any ideas would be appreciated  ....Mike
JamesTedrick
Esri Esteemed Contributor
Hi Mike,
"Within org" is automatically selected when "Everyone" is selected because Everyone includes everyone within the organization.  When "Everyone" is selected, sign-in is not required.
MichaelJabot
New Contributor III
James
Thank you! But when I share the survey people are asked to sign into the ORG.
I appreciate your help!
Mike
Michael Jabot, Ph.D.
Professor, Science Education
US Partner - GLOBE Program
NASA Earth Ambassador
Director, Institute for Research in Science Teaching
State University of New York at Fredonia
E250 Thompson Hall
Fredonia, NY 14063
716.320-0189 (Google Voice)
jabot@fredonia.edu
JamesTedrick
Mike,
Can you verify that sharing to everyone is enabled for your ArcGIS organization?  You can do this by logging into http://www.arcgis.com.  In the 'My Content' page, you will see a folder named 'Survey-<SURVEY NAME>'.  Clicking on that folder will show the survey form and the feature service.  Click on the checkboxes and attempt to share form there.  If the word 'Everyone' is disabled, you're not set up to share with everyone- this can be changed by your organization administrators.
MichaelJabot
New Contributor III
Jim
Thank you again. I am able to click on Everyone.
Another odd happening is that it does not stay shared. I share with everyone .... try it on a device ... and then when I log back in (either in Survey or ArcGIS) it is back to Not Shared.
Thank You again for your help
Mike
E250 Thompson Hall
Fredonia, NY 14063
jabot@fredonia.edu
ZhifangWang
Hi Mike,
From your description below,
Seems it's the same behavior of one of the known issues with the Survey123 website,  which is caused by lack of certain privilege in your ArcGIS Online account (share to everyone/org/group).
To help us confirm the cause of the problem, would you mind please to follow the steps below and let us know if there's something wrong in any step?
  1. Sign into www.arcgis.com with your organization account
  2. In the My Content page, find the survey folder on the left panel which you want to share
  3. In the survey folder, make sure you see 3 or 4 items
    • The last one, which has the "_stakeholder" postfix, will only appear if you have shared the survey in the Analyze tab of the Collaborate page once
  4. Unshare all items in the survey folder
    1. Select all items in the survey folder
    2. Click the Share button
    3. In the Share dialog, make sure to uncheck all checkbox, and click OK. This will make the entire survey completely private
      Please make sure that you can see all the Everyone (public), {your org name}, These groups options as below
  5. Sign into the Survey123 website (https://survey123.arcgis.com), go to the Submit tab of the Collaborate page, you should see all the checkboxes are not checked and also the “Currently, no one except you can submit data to the survey.” message on the left to the Save button
  6. Check Everyone (Public) and click Save
  7. After you see the Saved Successfully! message, go back to the My Content page in ArcGIS Online
  8. Check the Form item and the Feature Layer (hosted, view) item with _fieldworker postfix, click the Share button, to see if it's the same result as my screenshot below: Everyone (public) and {org name} checkboxes should be selected
  9. If you see the exactly same results in step 8, then your survey should work publicly, that means people can submit records to the survey without logging
MichaelJabot
New Contributor III
Zhifang
Thank you for emailing me!
When I get to Steps 5-6
This is what is displayed:
It won't let me uncheck the "Members of the Organization"
Thank you again
Mike
NASA Earth AmbassadorDirector, *Institute for Research in Science
Teaching*
E250 Thompson Hall
Fredonia, NY 14063
jabot@fredonia.edu
ZhifangWang
Hi Michael Jabot
What you saw in step 6 is expected, the "Members of the Organization" will always be checked if you check the "Everyone (public)" due to any members in your org can definitely access the survey if it's shared to public.
Is there any other exception you've encountered until step 9?
