search widget
1507
6
04-24-2017 08:46 PM
NedaPeiravian
New Contributor III
I try to create search widget for my map that when someone search the object id of the trees the map shows that tree with popup to user. the problem is the search widget didn't return objid.
Tags (3)
RobertScheitlin__GISP
Neda,
   Strange the search widget works for me with that change in your code. I turned off autosuggest (as it seems to have an issue with OID fields) is that what you mean does not work? When I type 34 in the widget and hit enter it take me to that tree. Here is the full code with corrections:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Interactive web map for CSULB Trees dataset</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/themes/light/main.css">
  <script src="https://js.arcgis.com/4.3/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/geometry/Extent",
      "esri/layers/FeatureLayer",
      "esri/widgets/Search",
      "esri/widgets/Legend",
      "esri/widgets/ScaleBar",
      "dojo/domReady!"
    ], function(Map, MapView, Extent, FeatureLayer, Search, Legend, ScaleBar) {
      var map = new Map({
        basemap: "gray"
      var initialExtent = new Extent({
        xmin: -118.13,
        xmax: -118.1,
        ymin: 33.77,
        ymax: 33.79
        //spatialReference: 102100
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 15,
        center: [-118.114090, 33.783823],
        extent: initialExtent
      var template = {
        title: "CSULB Tree Details, Tree ID: {tree_id}",
        content: "<li>Common name: <b>{common_name}</b></li>" +
          "<li>Scientific name: <b>{scientific_name}</b></li>" +
          "<li>Genus: <b>{genus}</b> </li>" +
          "<li>Specific epithet: <b>{specific_epithet}</b></li>" +
          "<li>Cultivar subspecies: <b>{cultivar_subspecies}</b> </li>" +
          "<li>Family: <b>{family}</b> </li>" +
          "<li>Condition: <b>{condition}</b> </li>" +
          "<li>Average of Trunk dbt: <b>{average_trunk_dbh_cm}</b></li>" +
          "<li>Height: <b>{hight_m}</b> Meter</li>" +
          "<li>Canopy height: <b>{canopy_height_m}</b> Meter</li>" +
          "<li>Canopy width: <b>{canopy_width_m}</b> Meter</li>" +
          "<li>Canopy shape: <b>{canopy_shape}</b> Meter</li>" +
          "<li>Biomass Mt: <b>{biomass_mt}</b></li>" +
          "<li>Co2 sequestration: <b>{co2_sequestration_kg}</b> Kg</li>" +
          "<li>Owner: <b>{owner}</b> </li>" +
          "<li>Photo: <b>{photo_urls}</b> Meter</li>" +
          "<li>Date planted: <b>{date_planted}</b> </li>" +
          "<li>ObjectId: <b>{objectid}</b> </li>",
        fieldInfos: [{
          fieldName: "canopy_width_m",
          format: {
            digitSeparator: true, // Use a comma separator for large numbers
            places: 0 // Sets the number of decimal places to 0 and rounds up
          fieldName: "average_trunk_dbh_cm",
          format: {
            places: 0
      var campus = new FeatureLayer({
        url: "http://services3.arcgis.com/vq5vGR4r1YX7ueLg/arcgis/rest/services/CampusTreeLayers/FeatureServer/1?t...."
      map.add(campus);
      var tree = new FeatureLayer({
        url: "http://services3.arcgis.com/vq5vGR4r1YX7ueLg/arcgis/rest/services/CampusTreeLayers/FeatureServer/0?t....",
        outFields: ["*"],
        popupTemplate: template
      map.add(tree);
      var search = new Search({
        view: view,
        sources: [{
          featureLayer: tree,
          searchFields: ["objectid"],
          displayField: "objectid",
          exactMatch: true,
          outFields: ["*"],
          placeholder: "Object ID",
          maxResults: 6,
          maxSuggestions: 6,
          suggestionsEnabled: true,
          minSuggestCharacters: 0
      view.ui.add(search, "top-right");
      var legend = new Legend({
        view: view,
        layerInfos: [{
          layer: campus,
          title: "CSULB Campus Land covers"
      view.ui.add(legend, "bottom-left");
      var scaleBar = new ScaleBar({
        view: view,
        unit: "non-metric"
      view.ui.add(scaleBar, {
        position: "bottom-left"
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
by Anonymous User
Not applicable
Hi
Can you please share some test objectIDs to test in application.
Neda,
  Your issue is that you are not setting up your search sources property correctly:
        view: view,
        sources: [{
          featureLayer: tree,
          exactMatch: true,
          outFields: ["objectid"],
          placeholder: "object ID",
          maxResults: 6,
          maxSuggestions: 6,
          suggestionsEnabled: false,
NedaPeiravian
New Contributor III
Hey Robert,
Thank you for fixing my code, although the search widget shows up with place holder name now, it cannot find the object id of trees, should I add any property to var tree?
Neda,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
      var map = new Map({
        basemap: "gray"
        xmin: -118.13,
        xmax: -118.1,
        ymin: 33.77,
        ymax: 33.79
        map: map,
        zoom: 15,
      var template = {
        fieldInfos: [{
          format: {
          format: {
            places: 0
      map.add(campus);
        outFields: ["*"],
      map.add(tree);
        view: view,
        sources: [{
          featureLayer: tree,
          exactMatch: true,
          outFields: ["*"],
          maxResults: 6,
          maxSuggestions: 6,
        view: view,
        layerInfos: [{
          layer: campus,
        view: view,
        unit: "non-metric"
  </script>
</head>
<body>
</body>
</html>
NedaPeiravian
New Contributor III
Yea, by turning off the autosuggest it works for me too. Thank you.
Great, Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
