Change 'Distress' Color Ramp?
2805
9
04-21-2017 08:26 AM
EddyClark
I'd like to change the color ramp used in the 'distress' appearance.
Tags (3)
IsmaelChivite
Esri Notable Contributor
Hi! This is not  possible at the moment. Would you simply want to flip the color  ramp or  define entirely new from and to colors?
EddyClark
New colors.  I'd like to go from blue to brown.
GaryWorley1
I too would like to see either an inverse of the current distress color ramp, or a option to choose color ramp start and end colors.
DungaBazao
Dear Ismael,
Is it possible at least to invert the color ramp (ie - green for 10 and red for 0)?
Dunga
EstellaSmith
New Contributor III
Is there a way to flip the color ramp?
Estella Smith
HélèneTouyéras
Occasional Contributor II
I would also like to reverse the color ramp, to make a visual slider from 0/bad/red to 10/good/green. I am testing version 3.0.014 and this functionality is not available.
Thank you.
SimonJackson
Occasional Contributor III
+1 on option to flip the color ramp
Jim-Moore
Hi All
The range question type was introduced in Survey123 version 3.6. It's similar to the distress appearance, but gives you more flexibility. With range questions you can:
  • Control the range
  • Use integer or decimal field type
  • Set the step interval
  • Show or hide tick marks
  • Choose a colour scheme!
The range question type is covered in detail here: Range—Survey123 for ArcGIS | Documentation
Best,
Jim
Eddy ClarkGary WorleyDunga BazaoHélène TouyérasSimon Jackson‌
HélèneTouyéras
Thanks a lot for the good news, Jim! This looks very flexible, thus very nice !!
