RuntimeError: workspace already in transaction mode?! Help, pls!
5102
04-18-2017 07:32 AM
by Anonymous User
Not applicable
Hi all -
I keep getting:
Runtime error
  File "<string>", line 26, in <module>
RuntimeError: workspace already in transaction mode‍‍‍‍
when I run my script. I can't sort out why.
Here's my code. (Not loving how the formatting works here.)
# Move points based up current lat/lon
#grab stuff you need
import arcpy
import os
print "Imported Libraries."
# Set variablesfilepath = r'S:\AGR\AGR-Shared\AGR-GIS\AGR_Data\Connection to cloud.agriculture.vermont.gov.sde'
fc = "AGRGISDATA.DBO.ApiariesWGS"
fc_path = os.path.join(filepath, fc)
fields = ['Longtitude','Latitude','SHAPE@XY']
#arcpy.env.workspace = fc_path #I don't think this is needed.
workspace = os.path.dirname(fc_path)
editor = arcpy.da.Editor(workspace) #this one throws "RuntimeError: workspace already in transaction mode"
print "Set vars."
editor.startEditing(False, True)
editor.startOperation()
print "Editor Commands."
#create curser on fc
#try:
#print "Trying"
with arcpy.da.UpdateCursor(fc_path,fields) as cursor:
print "With"
for row in cursor:
print "for row in cursor"
x = row[0]
y = row[1]
xy = (x,y)
pnt = xy
row[2] = pnt
cursor.updateRow(row)
print "Updated Rows."
#finally:
editor.stopOperation()
editor.stopEditing(True)
del editor
print "It worked!"‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
My code is indented properly, I just couldn't make it do so with the syntax highlighter here. I'm sure there's a way, but I haven't figured it out.
Anyway, I've been trying different things to get this code running again, and I'm out of ideas. Would love some help.
Thx
JG
by Anonymous User
Not applicable
It was an SDE locking issue, just in case anyone in the future is looking this up.
by Anonymous User
Not applicable
RebeccaStrauch__GISP
Just in case it is a locking issue causes by a step in your script, you can use  time.sleep()  to pause what a lock is released.  I have to do this with some of my scripts which seem to run faster than the system is responding.  for example
import time
def mySleep(secs):
     print("     zzz...sleeping {0} seconds to allow network file status to catch up....".format(secs))
     time.sleep(secs)
mySleep(10)
AdrianWelsh
MVP Honored Contributor
I had this same error but it came up in ModelBuilder in ArcGIS Pro 2.0. It was a file geodatabase and I just closed my project and opened it again, and it ran just fine. Is there a way to put in a sleep timer thing in #ModelBuilder‌?
AdanDeLeon
After reading all sorts of fixes for this issue online, neither worked for my situation and ended up finding out that table that I was trying to insert need to have edit rights under "Privileges"!  haha
