So in February we set up our Publish & Edit Geodatabases. Works great. And through the help of Jake Skinner learned how to synchronize changes. Which, again, works perfect. Jake also provided information about using Python to schedule Scheduling a Python script to run at prescribed times- Help | ArcGIS Desktop, but we need help in automating the full process before we set up a schedule.
Currently I manually stop the services, kill the connections, reconcile and post the versions, compress the SDE, synchronize the changes from edit to publish, then start the services.
We are looking for best practices, how your organization handles this, what works, what doesn't work.
I appreciate the feedback, and thanks to all in advance.
Hi John,
Attached is a script that I use often when working with customers. The script stops all ArcGIS Server services, reconcile/posts all version (does not delete the versions) to the DBO.Default version, compresses the database, then starts all the services.
The script will also send an e-mail if there was an error during the reconcile/post or the compress. An e-mail will also be sent when the compress is successful.
The one thing you will want to add is the synchronization for your replicas before the reconcile/post. Also, you will want to be sure to update statistics and indexes after the compress.
