Survey response submission fails in Survey123 web app.
556
04-14-2017 12:38 PM
AlekKreiger
New Contributor III
Receive this error message:
"Conversion failed when converting from a character string to uniqueidentifier."
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Alek,
Can you share the XLSFile of the survey?  I'm not seeing the same behavior.
AlekKreiger
New Contributor III
I'm unable to share the .xls file at this time since I am out of my office for a week and didn't bother to bring a copy with me. The only difference between my form and a template or what might be expected is that I've included images with an <img> tag in the label column so that I can center the image in the form instead of referring to the image file in the 'media::image' column. Could this be causing the problem?
