Select features and zoom to layers
3703
18
04-15-2017 08:29 AM
SibghatUllah1
I am trying to select highlight features and zoom to selected features layer extent.My code below runs but doesn't highlight any feature.
on(dom.byId("try"), "click", function () {
var queryTask = new QueryTask("http://localhost:6080/arcgis/rest/services/RAEC/MapServer/12");
//build query filter
var que = new Query();
que.returnGeometry = true;
que.outFields = ["FeederID", "OBJECTID"];
que.outSpatialReference = { "wkid": 32640 };
que.where = "FeederID<> ''";
symbol = new SimpleMarkerSymbol();
symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
symbol.setColor(new Color([255,255,0,0.5]));
queryTask.execute(que,showResults);
function showResults(featureSet) {
map.graphics.clear();
var resultFeatures = featureSet.features;
for (var i=0, il=resultFeatures.length; i<il; i++) {
var graphic = resultFeatures;
graphic.setSymbol(symbol);
map.graphics.add(graphic);
RobertScheitlin__GISP
OK,  That is what does not make sense then.
      query = new Query();
      query.returnGeometry = true;
      query.outFields = ["FeederID"];
      query.outSpatialReference = map.spatialReference;
line 2 and line 4 should cause the returned queries geometry to be in the maps spatial reference (WKID 102100).
You could try to manually set it:
query.outSpatialReference = {"wkid": 102100};
Sibghat,
   Have you placed a break point or a console statement in the showResults function to see if you are getting results from your query?
SibghatUllah1
Yes query is running fine and passing geometry object, attribute object and graphics symbols.
SibghatUllah1
Dear Robert,
I have make a new html with query.it is running and showing features without adding basemap. when i add
basemap: "topo",
center: [58.871192 , 20.646328],
zoom: 12
The query still runs and results are shown in different area .Something with projection is the error.Please guide
<!DOCTYPE html>
<html>
<head>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.claro .dijitContentPane {
font-family: "Lucida Grande","Segoe UI","Arial",sans-serif;
font-weight: normal;
font-size: small;
</style>
<script src="https://js.arcgis.com/3.20/"></script>
<script>
var map;
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/tasks/QueryTask",
"esri/tasks/query",
"esri/symbols/SimpleMarkerSymbol",
"esri/InfoTemplate",
"dojo/_base/Color",
"dojo/dom",
"dojo/on",
"dojo/domReady!"
], function(Map, ArcGISDynamicMapServiceLayer, QueryTask, Query, SimpleMarkerSymbol, InfoTemplate, Color, dom, on) {
//create map and add layer
map = new Map("mapDiv",{
basemap: "topo",
zoom: 12
var layer = new ArcGISDynamicMapServiceLayer(
"http://localhost:6080/arcgis/rest/services/RAEC/MapServer");
map.addLayer(layer);
//initialize query task
//initialize query
//initialize InfoTemplate
infoTemplate = new InfoTemplate("${FeederID}", "Name : ${FeederID}<br/> ");
//create symbol for selected features
symbol.setSize(10);
//write "Get Details" button's click event
on(dom.byId("runQuery"), "click", executeQueryTask);
function executeQueryTask() {
//set query based on what user typed in for population;
query.where = "FeederID<> ''";
//execute query
queryTask.execute(query,showResults);
//remove all graphics on the maps graphics layer
//Performance enhancer - assign featureSet array to a single variable.
//Loop through each feature returned
//Get the current feature from the featureSet.
//Feature is a graphic
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
</script>
<body>
<br/>
<input type="button" value="Get Details" id="runQuery" />
<div id="mapDiv" style="width:600px; height:600px; border:1px solid #000;"></div>
</body>
</html>
Sibghat,
  Just add this line with your other query properties:
query.outSpatialReference = map.spatialReference;‍‍
SibghatUllah1
i have already tried both but no success.
query.outSpatialReference={wkid :"32640"}; my map service wkid
query.outSpatialReference = map.spatialRefernce;
RebeccaStrauch__GISP
Resort Robert would know better than I would, but I'm wondering if it is a spelling error/typo
try
Also, I would add spaces around your = in the first line.
edit.   Talking about typos...I just noticed my iPad had "auto corrected" your name Robert.
Sibghat,
  Rebecca is correct I made a spelling error in my reply previously (I have since edited it).  It should be as Rebecca states.
SibghatUllah1
Now getting this error
Map: Geometry (wkid: 32640) cannot be converted to spatial reference of the map (wkid: 102100)
i was thinking to change my code using feature selection.
Sibghat,
  Based on this code:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      font-family: "Lucida Grande", "Segoe UI", "Arial", sans-serif;
      font-size: small;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "esri/tasks/query",
      "dojo/_base/Color",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      map = new Map("mapDiv", {
        basemap: "topo",
        center: [58.871192, 20.646328],
        zoom: 12
      //initialize query
      symbol.setSize(10);
      symbol.setColor(new Color([255, 255, 0, 0.5]));
        //execute query
        queryTask.execute(query, showResults);
          for (var i = 0, il = resultFeatures.length; i < il; i++) {
            var graphic = resultFeatures[i];
  </script>
  <body>
    <br/>
  </body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Your Map would be in WKID 102100, because you specify the maps basemap as topo. Now with query.outSpatialReference = map.spatialReference; this will cause your query results to return in WKID 102100 as well so the graphics should appear in the correct location.
Are you seeing something different than this?
