AnsweredAssumed Answered
Wait for AddField to finish until running CalculatField
Question asked by timw1984 Champion on Apr 14, 2017
Latest reply on Apr 17, 2017 by curtvprice
Hey everybody,
I am creating python toolbox and one of the tools adds a bunch of fields to a feature class that the user chooses and after wards calculates those fields with values from the original feature class. I run into the issue that the field calculations can't run because the fields haven't been added yet.
This is the code I use:
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the .pyt file)."""
        self.label = "My first python toolbox"
        self.alias = "Examples"
        # List of tool classes associated with this toolbox
        self.tools = [Tool1]
class Tool1(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Nena Street Tool"
        self.description = "Example showing how to create a value table tool with drop downs"
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # Define Parameter 0
        # Param0 will be a FeatureLayer
        param0 = arcpy.Parameter(displayName = "Your Street Layer",name="Site_layer",datatype="GPFeatureLayer",parameterType="Required",direction="Input")
        # Define Parameter 1
        param1 = arcpy.Parameter(displayName = "",name="Activity_layers",datatype="GPValueTable",parameterType="Optional", direction="Input")
        param1.columns=[["String","NENA Field"],["String","Your Field"]]
        # This says the filter on the second column will be a value List
        param1.filters[1].type="ValueList"
        param1.value = "Source; Updatedate; Effective; Expire; RCL_NGUID; AdNumPre_L; AdNumPre_R; FromAddr_L; ToAddr_L; FromAddr_R; ToAddr_R; Parity_L; Parity_R"
        # This adds a dummy value to the list, this will get overwritten by the updateParameters function
        param1.filters[1].list=["Please Select a street layer"]
        # Create a list of parameters and return
        params = [param0,param1]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        if parameters[0].altered:
          fields = arcpy.ListFields(parameters[0].value)
          mylist = []
          for field in fields:
             mylist.append(field.name)
          parameters[1].filters[1].list = mylist
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        try:
            # Some code to show that I had managed to get what I wanted intot the ValueTable
            data = parameters[1].values
            arcpy.AddField_management(parameters[0].value, "Source", "TEXT", "", "", "75", "", "NULLABLE", "NON_REQUIRED", "")
            arcpy.AddField_management(parameters[0].value, "DateUpdate", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
            arcpy.AddField_management(parameters[0].value, "Effective", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
            search = 'Source'
            for sublist in data:
              if sublist[0] == search:
                final = sublist
                mysource = final[1]
                sourceData = "[" + mysource + "]"
                arcpy.CalculateField_management(parameters[0].value, "Source", sourceData, "VB", "")
                break
        except arcpy.ExecuteError:
            messages.addErrorMessage(arcpy.GetMessages())
In line 75 I add the "Source" field and in line 84 I try to calculate it, but I get the error that the "Source" field does not exist.
Any help would be appreciated.
Tim
Outcomes
