I am trying to design a simple expression in filter or query with a time component. I can create and make work a filter or query without time but when I add time to the expression I get 0 records as a result.
This is snip of the data set
This is the expression set
With the date I have tried "Is on" and "is in between"
Dataset has 152K total records
Hi James,
Do you see a similar result when using the date filter in the web map?
I would recommend contacting technical support to troubleshoot this issue.
Web AppBuilder for ArcGIS
