add Feature Table to multiple Feature Layers
3162
04-12-2017 08:47 AM
SaraEL_MALKI
Hi everyone,
as the title says, I wanna add the feature Table to multiple Feature Layers,
Here is the code provided by ArcGIS API for JavaScript website (the code is adding the featureTable JUST for ONE featureLayer) :
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>FeatureTable - Custom Menu Items</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
  <script src="https://js.arcgis.com/3.20/"></script>
  <style>
    html, body, #map {
      width: 100%;
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
      "esri/layers/FeatureLayer",
      "esri/dijit/FeatureTable",
      "esri/geometry/Extent",
      "esri/graphicsUtils",
      "esri/tasks/query",
      "esri/symbols/PictureMarkerSymbol",
      "esri/map",
      "dojo/dom",
      "dojo/parser",
      "dojo/ready",
      "dojo/on",
      "dijit/layout/ContentPane",
      "dijit/layout/BorderContainer"
    ], function (
      FeatureLayer, FeatureTable, Extent, graphicsUtils, Query, PictureMarkerSymbol, Map,
      dom, parser, ready, on, ContentPane, BorderContainer
      parser.parse();
      ready(function(){
        var map = new Map("map",{
          basemap: "dark-gray",
          extent: new Extent({xmax: -13035353.854156237, xmin: -13053431.211345658,
            ymax: 4038351.1313028745, ymin: 4034089.766975982,
            "spatialReference":{"wkid":102100,"latestWkid":3857}
        //Load a FeatureTable to the application once map loads
        map.on("load", loadTable);
        function loadTable(){
          // editable FeatureLayer
          var myFeatureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/RedlandsEmergencyVehicles/FeatureServer/...", {
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"],
            visible: true,
          // set a selection symbol for the featurelayer
          var selectionSymbol = new PictureMarkerSymbol("https://sampleserver6.arcgisonline.com/arcgis/rest/services/RedlandsEmergencyVehicles/FeatureServer/...", 48 ,48);
          myFeatureLayer.setSelectionSymbol(selectionSymbol);
          // listen to featurelayer click event to handle selection
          // from layer to the table.
          // when user clicks on a feature on the map, the corresponding
          // record will be selected in the table.
          myFeatureLayer.on("click", function(evt) {
            var idProperty = myFeatureLayer.objectIdField,
              feature,
              featureId,
              query;
            if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty]) {
              feature = evt.graphic,
              featureId = feature.attributes[idProperty];
              query = new Query();
              query.returnGeometry = false;
              query.objectIds = [featureId];
              query.where = "1=1";
              myFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);
          // Redlands police vehicle locations layer
          // this layer is an editable layer
          map.addLayer(myFeatureLayer);
          //create new FeatureTable and set its properties
          var myFeatureTable = new FeatureTable({
            featureLayer : myFeatureLayer,
            map : map,
            editable: true,
            syncSelection: true,
            dateOptions: {
              datePattern: 'M/d/y',
              timeEnabled: true,
              timePattern: 'H:mm',
            // use fieldInfos object to change field's label (column header),
            // change the editability of the field, and to format how field values are displayed
            // you will not be able to edit callnumber field in this example.
            fieldInfos: [
                alias: 'Call Number',
                editable: false //disable editing on this field
                alias: 'Current Speed',
                format: {
                  template: "${value} mph" //add mph at the of the value
                alias: 'Vehicle Type'
                alias: 'Unit Name'
            // add custom menu functions to the 'Options' drop-down Menu
             menuFunctions: [
              label: "Filter Available Emergency Vehicles",
              callback: function(evt){
                console.log(" -- evt: ", evt);
                // set definition expression on the layer
                // show only available emergency vehicles
                myFeatureLayer.setDefinitionExpression("status = 0");
                // call FeatureTable.refresh() method to re-fetch features
                // from the layer. Table will only show records that meet
                // layer's definition expression creteria.
                myFeatureTable.refresh();
              label: "Show All Emergency Vehicles",
                myFeatureLayer.setDefinitionExpression("1=1");
          }, 'myTableNode');
          myFeatureTable.startup();
          // listen to refresh event
          myFeatureTable.on("refresh", function(evt){
            console.log("refresh event - ", evt);
  </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
      <div id="map"></div>
    </div>
    <div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%;">
      <div id="myTableNode"></div>
    </div>
  </div>
</body>
</html>
Tags (1)
RobertScheitlin__GISP
Sara,
  So what have you tried? I would suggest adding a tab container that way you can add multiple tables as tabs.
