Try it live - Basemap garbled (Description and Solution)
780
04-11-2017 03:53 AM
JensBuchta
Just in case, anyone trying the most basic sample and seeing a corrupt basemap, here's an explanation and the solution.
Steps to reproduce
  1. Use a recent version of Chrome or Firefox (other browsers not tested)
  2. Navigate to https://notebooks.esri.com
  3. Create a new notebook (New -> Python 3)
  4. Enter the following script code
  5. from arcgis.gis import *
    gis = GIS()
    gis.map()
  6. Run the cell (<Ctrl-Enter>)
  7. The result looks similar to this:
  8. ArcGIS API for Python - Broken Basemap
Explanation
The notebook is running on an https (secured) connection. However, as we didn't authenticate to ArcGIS Online, we're getting the tiles (and some .js-code) from an http (non-secured) connection. Chrome and Firefox block that unsecured JavaScript code.
Workaround 1
Instead of using the secured https connection, use http://notebooks.esri.com instead. As everything will be loaded without encryption, Chrome / Firefox are happy with that.
However: If you change your script to an authenticated AGOL-Session, you will send your username / password in plain-text through the net!
Workaround 2
Both Chrome and Firefox have the option to explicitly allow loading unsecure content. In Chrome, there's a small icon on the right, in Firefox, it's right beside the https-indicator.
BillMajor
Thanks for the feedback.  This has now been corrected.  You should now be able to use https:// without needing a workaround.
