Create a marker using people's initials
942
04-06-2017 10:54 AM
by Anonymous User
Not applicable
Hi all,
Is there a way in Javascript and ESRI's api to get the fullname column from my Feature layer's column, transform the full names into initials and render it in a marker that would have people's initials?
Alex
Tags (1)
RobertScheitlin__GISP
Alex,
   Sure once you have the name value from the attribute just split the string based on " " (spaces) and then get the first letter using .substring(1, 1); and save that to a new string to concatenate with the other first letters and then use a TextSymbol
TextSymbol | API Reference | ArcGIS API for JavaScript 3.20
Alex,
by Anonymous User
Not applicable
I am now getting the initials in a variable but at the end of the loop I get an error:
Here is my code:
queryTaskauto.execute(queryauto, function (results) {
                arrayUtil.forEach(results.features, function(value, index){
                var arraynew = value.attributes.f3;
                var words = arraynew.split(' ');
                var text = '';
                $.each(words, function () {
                text +=  this.substring(0, 1);
                console.log(text);
                console.log(words);
Any idea?
by Anonymous User
Not applicable
This worked:
if (arraynew === null){
                console.log("Dont split");
                } else {
                var text = '';
                console.log(text);
                console.log(words);
