Zoom to Issues
1386
12
04-04-2017 06:51 AM
jaykapalczynski
I included the relevant code I think for this issue....
I have my Map
I am setting the spatial reference of the query results
Using the results to create a new graphics Layer
The Graphics are located in the correct position so that works fine...
BUT when the below runs it zooms off the coast of Africa.  I know this is a Spatial Reference issue but not sure where and how to set it...
Thoughts?
var extGraphics = graphicsUtils.graphicsExtent(map.graphics.graphics);
map.setExtent(extGraphics);
    //SET THE MAP
    var map = new Map("map", {
        basemap: "dark-gray",
        center: [-79.665, 37.629],
        zoom: 8,
        logo: false,
        showLabels: true
      // QUERY FOR County and Squad
      var queryTask = new QueryTask("https://vafwisdev.dgif.virginia.gov/arcgis/rest/services/Projects/Summons/FeatureServer/5");
      var query = new Query();
       query.outSpatialReference = {wkid: 4326}; //4326 //102100 //3857
       query.returnGeometry = true;
/// SNIP
      var countiesGraphicsLayer = new GraphicsLayer({opacity:0.75});
      //This is the click event for the graphics on the map
      countiesGraphicsLayer.on("click", selectGrid);
      map.addLayer(countiesGraphicsLayer);
/// SNIP
        arrayUtils.map(results.features, function(feature) {
          feature.setSymbol(symbol);
          feature.setInfoTemplate(infoTemplate);
          countiesGraphicsLayer.add(feature);
          var featureAttributes = feature.attributes;
          for (var attr in featureAttributes) {
            resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
          resultItems.push("<br>");
        dom.byId(ActivePane).innerHTML = resultItems.join("");
        map.setExtent(extGraphics); ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
/// SNIP‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Jay,
   Your next issue is this line:
you are not adding your results to map.graphics anymore:
var extGraphics = graphicsUtils.graphicsExtent(countiesGraphicsLayer.graphics);
Jay,
   You are using an esri basmap which is in WKID 102100 but when you query your map service you are setting the out spatial reference to WKID 4326. That would cause your issue.
you should use:
query.outSpatialReference = map.spatialReference;
jaykapalczynski
If I do this
and may map looks like this:
zoom: 8,
logo: false,
showLabels: true
Now its not only zooming to Africa but drawing the graphics there....tried clearing my cache etc...
Jay,
jaykapalczynski
I got it to work but ONLY by setting it this way.
query.outSpatialReference = {wkid: 102100};
if I use this is does not work.
jaykapalczynski
Its working but zooming in a bit much....can I back off the zoom a little bit to include all the graphics?
Strange indeed. Working off the code I provided in your previous question I had no problem using
and
jaykapalczynski
think its working now...ONE second.....Thanks Again dude....BRB
jaykapalczynski
seems to be working now....but still have to set the spatial reference to
instead of query.outSpatialReference = map.spatialReference;
Last question....is there a way to set the extent but then back off a bit....it zooms fine but a little to close for my liking...can I back off a fraction or some setting.
Jay,
   Just use:
map.setExtent(extGraphics.expand(1.2));
