Hi guys i am trying to edit Date in WAB 2.4 but i need the date picker appear with date and time but when i edit the date picker just show me the date like the image prueba_widget, but i need the date time like the ArcGIS Online Table Editor with date and time at the same edition. If you can give me some ideas how to edit WAB 2.4 for developers to do that i will be awsome, thank you.
Solved! Go to Solution.
Juan,
In your web map did you configure the popup and for that field did you check the show time?
If so then you should see a time field also.
Juan,
Thank You Robert that was the solution ! Its help me a lot.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
