AnsweredAssumed Answered
Issue with Solar Calculation and Projection
Question asked by alfann.net on Mar 29, 2017
Latest reply on Mar 30, 2017 by alfann.net
Hi all,
I am using this example to my project:
Explore Solar Radiation | ArcGIS for Local Government
I have a layer of 3D Buildings as shown in the image:
When I applied the Calculation of the Solar Radiation on these Buildings Roofs, I found that the calculation is shown ONLY on the right 3d Building, whereas the middle and the left buildings are not calculated. Like this image:
Then, I suggested to myself to select these two buildings ONLY  and process the calculation of solar radiation to detect where is the problem. I did, but the result was not shown. Then I zoomed to the resulted layer, and found that these two 3D buildings are on Canada map, as shown in this image.
I really surprising why this happened!
All of the 3D Buildings are in one layer as I mentioned earlier.
Is there any suggestion or solution why this problem occur in my work?
Appreciate  your helps.
Dan Patterson
Outcomes
