Enter a String for all the Records of a Field
1268
12
03-29-2017 12:00 PM
AzaN
New Contributor III
I have a Text field (Status), which I need to enter a string ('Existing') into all the cells of this field. I have 300 records and prefer to do it via Python or JavaScript. For some reason, I get error messages for my script. Can anyone help me with that? Thanks.
IanMurray
The only reason this wouldn't work is if your field was not a text field, or your text field character limit was less than 8 characters.
IanMurray
If you are having issues with a script, it is recommended to post the script and the error so people know where you are going wrong.
http://desktop.arcgis.com/en/arcmap/10.3/tools/data-management-toolbox/calculate-field.htm
arcpy.CalculateField_management("yourfilehere", "Status",
                                'Existing', "PYTHON_9.3")
AzaN
New Contributor III
Thanks for your response. I am using the Field calculator. Could you please give the script I should enter into that? By the way, my field name is Status.
AzaN
New Contributor III
My script:
!Status!.str('Existing')
Error message:
There was a failure in processing....
IanMurray
Try just putting in 'Existing' as your Expression.
AzaN
New Contributor III
Already did. Same error message.
IanMurray
AzaN
New Contributor III
Awesome!  Thank you so much. It worked!
IanMurray
Sometimes a picture is worth about 25 words....
JoshuaBixby
MVP Esteemed Contributor
Did you try the code posted by iamurray‌, from your original question I think that code should work.
