Arc 10.5 losing records from geodatabase
1004
03-29-2017 12:15 PM
JosephCornellisson
I just upgraded to arc 10.5.  I have a geodatabase that has 4527 records.  When I open the database it shows a record count of 4527. If I do anything (such as a sort) the record count changes to 3539.  I reopened it and selected all the records and then did  a sort and got this result4527 selected out of 3539Same thing happens in catalog.  On opening the geodatabase I see all the records.  After any operation (sorting) 888 records disappear.
What is going on?? Do I need to do something to upgrade the gdb??
Help -
thanks
Joe
George_Thompson
Esri Frequent Contributor
Hi Joe,
What version is the geodatabase in? Is this a file geodatabase or an enterprise geodatabase (eGDB)?
If using an eGDB, answer the following questions:
What is the RDBMS version and OS that it is running on?
Is the data versioned?
That will give some more information that may be needed.
--- George T.
JosephCornellisson
It is a file geodatabase that was created in 10.3. It is not versioned.
Joe
Joseph Cornellisson
Geologist/GIS Manager
Division of Minerals Evaluation
Office of Valuation Services, U.S. Department of the Interior
Denver Federal Center, Bldg 46, Suite 102
PO Box 25247
One Denver Federal Center
Denver, CO 80225
Phone: 303-969-5941
Fax: 303-969-5949
E-mail: Joseph_cornellisson@ios.doi.gov <Joseph_Cornellisson@ios.doi.gov>
The information in this email is confidential and may be legally privileged
Access to this email by anyone other than the intended addressee is
unauthorized. If you are not the intended recipient of this message, any
review, disclosure, copying, distribution, retention, or any action taken
or committed to be taken in reliance on it is prohibited and may be
unlawful. If you are not the intended recipient, please reply to of
forward a copy of this message to the sender and delete any attachments, or
any copies thereof from you system.
JayantaPoddar
MVP Esteemed Contributor
Create a new file geodatabase. Import the corresponding feature classes to the newly created GDB.
I hope this will resolve the issue.
Think Location
JosephCornellisson
I tried this. It only imported the 3539 records.
thanks
Joseph Cornellisson
PO Box 25247
Denver, CO 80225
Phone: 303-969-5941
Fax: 303-969-5949
