Identify Route Location measure
1499
03-28-2017 02:56 PM
SusanH
Hi.
Is there a way using the tool Identify Route Location  measure to display the measure as more than 3 decimal.  I have changed my setting in Editor and this has no impact.   I do not have access to the Esri Roads and Highways extension.
Susan
TedKowal
Occasional Contributor III
It is the registry you have to change .....
Identify route locations
REG_DWORD: HKCU\Software\ESRI\Desktop10.1\ArcMap\DynSeg\IdentifyDecimalPlaces
Description: This controls the number of decimal places for numbers used on the Identify Route Locations dialog. Valid values are 0 to 10; anything else (or non-existent) will result in the default of 3 being used.
If you have the [ARCGISFOLDER]\Utilities\ArcmapAdvancedSetting.exe you can change it on the Linear Referencing Tab
TedKowal
SusanH
Thanks Ted!   That answer was very helpful!
MatthewLeonard
New Contributor III
Thanks - I wish I had found this years ago. Just now decided to search for the answer instead of accepting the default 3 decimal places like I always have.
