Web AppBuilder Dart Theme overrides color with !important
1270
5
03-28-2017 03:43 AM
GijsBoekema
The Dart Theme uses:
.jimu-widget-frame.jimu-container * {
    color: #ffffff !important;
    outline: none;
  which causes strange behavior of our own color css styling:
If we remove the * and !important it looks like this:
Dart Theme is the only one causing problems like this. What can we (or ESRI) do about this?
Thanks in advance for your answer!
RobertScheitlin__GISP
Gijs,
   So in your code for your toolbar at the bottom of the widget you need to have a css rule with higher specificity that will use !important to override the
So hopefully your toolbar as a class applied to it and you can just add a rule to it
This is not just copy and paste code, it is just an example of a higher specificity css rule.
.jimu-widget-frame.jimu-container .mytoolbar.button {
    color: green !important;
EmilyCaruccio
New Contributor III
Robert Scheitlin, GISP‌, I have a similar question. Is it possible to completely remove the container so my text is black and hyperlinks will be blue?
Sure you would just set the containers background color to a color with 0 opacity.
EmilyCaruccio
New Contributor III
How do I do that?
.blahblah {
  background-color:rgba(0,0,0,0);
