AnsweredAssumed Answered
clr.dll (ArcGIS crashes while opening *.mxd and *.gdb)
Question asked by kelvinsartorius on Mar 27, 2017
I'm having trouble with accessing files using both ArcMap and ArcCatalog. They both seem to be crashing after trying to acces a certain *.gdb file. Apart from this all *.mxd files that created before the problem occurred are crashing the application while being opened. However that's not the case for newly created files.
Below I pasted the error message that I got(german):
Problemsignatur:
Problemereignisname: APPCRASH
Anwendungsname: ArcCatalog.exe
Anwendungsversion: 10.5.0.6491
Anwendungszeitstempel: 581b945a
Fehlermodulname: clr.dll
Fehlermodulversion: 4.6.81.0
Fehlermodulzeitstempel: 5584e56f
Ausnahmecode: c00000fd
Ausnahmeoffset: 004219ca
Betriebsystemversion: 6.3.9600.2.0.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: 896a
Zusatzinformation 2: 896a0301ab2b64e7a8926dc0680e98c8
Zusatzinformation 3: 90fd
Zusatzinformation 4: 90fd04c2650dff8dcbc643eae487923c
EDIT:
I repaired ArcGIS installation with Setup -> Repair, but it hasn't solved anything.
Apart from this I tried using ArGIS Earth Repair (although I'm not sure if this  makes sense) but it crashes as well, showing following message:
Problemsignatur:
Anwendungsname: ArcGIS_Earth_Repair.exe
Anwendungsversion: 0.0.0.0
Anwendungszeitstempel: 56757a01
Fehlermodulname: KERNELBASE.dll
Fehlermodulversion: 6.3.9600.17415
Fehlermodulzeitstempel: 54504ade
Ausnahmecode: c000007e
Ausnahmeoffset: 00014598
Zusatzinformation 1: 7d44
Zusatzinformation 2: 7d445f89c199ae2e4656c7f6c1d0c2d2
Zusatzinformation 3: 63d6
Zusatzinformation 4: 63d6498b61c26b87b6ca73fec3c8b7ad
While repairing the *.mxd file with MXD Doctor I got following error message:
Problemsignatur:
Anwendungsname: MXDDoctor.exe
Anwendungszeitstempel: 581b9494
Fehlermodulname: MSVCR120.dll
Fehlermodulversion: 12.0.21005.1
Fehlermodulzeitstempel: 524f7ce6
Ausnahmecode: c0000005
Ausnahmeoffset: 0000f608
Zusatzinformation 1: a577
Zusatzinformation 2: a577f104ae7c2d6969b1b07d9212a954
Zusatzinformation 3: 6024
Zusatzinformation 4: 6024de01a2ddc6072438ac8806005b9b
So summing up:
Some *.dll files are causing this problem (clr.dll, KERNELBASE.dll and MSVCR120.dll). Is there any fix, patch or update  for these files?
Outcomes
