Registering a folder fails “The arcgis server is not able to connect to the specified directory”
4970
8
03-26-2017 02:01 PM
abdullahqasrawi
Registering a folder fails “The arcgis server is not able to connect to the specified directory”,
I got the error below while registering a folder in ArcGIS Server 10.5 (shown in the screenshot below)
What might be the issue here?
JayantaPoddar
MVP Esteemed Contributor
Ensure the folder has read permission for following accounts
- ArcGIS
- Current User
Think Location
abdullahqasrawi
Thanks for you advice
Its helpful
MajdoleenO_A__Awadallah
Occasional Contributor III
I agree with jayanta.poddar, you need to give the current user a permission with full control on the shared folder, attached.
Best,
Majdoleen
JamalNUMAN
Legendary Contributor
That is good to know that the ArcGIS server user account needs to have full permission on the source data folder to avoid copying it to the machine where the ArcGIS Server is installed
Jamal Numan
AyeshaAnwar
Hi
I am still having the same error while i have set the permission full control to arcgis and my user account.
Can you please help me to find the solution
JamalNUMAN
All what you need to do is to grant the ArcGIS Server User Account a full access to the storage. For example, if ArcGIS Server User Account is in machine M1 and the data is in machine M2, then the ArcGIS Server User Account needs to have full permission on the storage of machine M2 (its C or D drive)
Jamal Numan
JoshWhite
Regular Contributor III
UPDATE: I was able to switch everything to the UNC path and it worked.  Kind of a pain but it is what it is.  Had to manually enter the path to add the folder connection.
I have given both the current user and the ArcGIS Server Account full permissions and still have the same issue.  The data is on a mapped network drive.  I've looked into changing the source of the data to the UNC path but Pro doesn't seem to allow that or at least I can't figure out how to do it.  I have also attempted to register the drive in Server Manager but that doesn't work either.  I don't really understand this as I have used this method before in ArcMap from the same location (well the UNC path \\servername\) without issue just not in Pro.
Josh White, AICP
Principal Planner
City of Arkansas City
