Help debug this Python field calculator script
1136
03-17-2017 08:35 AM
MichaelLenore1
New Contributor III
I can't get this to work. I want it to return "No Data" if the field PROP_CLASS is empty (see line 32). As things stand it returns "Other." It works otherwise. Any ideas?
def CATEGORY(prop_class):
  if '200' <= prop_class <= '283':
    return "Residential"
  elif '310' <= prop_class <='312':
  elif prop_class == '322':
  elif '410' <= prop_class <= '413':
  elif prop_class == '416':
  elif prop_class == '693':
  elif prop_class == '300':
    return "Public/Vacant"
  elif  '313' <= prop_class <= '321':
  elif  '323' <= prop_class <= '380':
  elif prop_class == '531':
  elif prop_class == '552':
  elif prop_class == '560':
  elif '590' <= prop_class <= '593':
  elif prop_class == '695':
  elif  '900' <= prop_class <= '994':
  elif prop_class is None:
    return "No Data"
  else:
    return "Other"
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
An empty string is '', not NoneNone is what is returned when a field is NULL.
JoshuaBixby
When you say "empty," do you mean NULL or an empty string?  If "No data" isn't being returned now, what is?
MichaelLenore1
New Contributor III
Empty string. Now returns "Other."
JoshuaBixby
MichaelLenore1
New Contributor III
Aha. Thought I'd tried ==' ' but I guess I hadn't - that did the trick. thanks!
