hi all:
i want to draw some polyline in Bitmap using SimpleDisplay,but the bitmap is blank,what's wrong ,
thx!
the code is:
static void Main(string[] args)
//ESRI License Initializer generated code.
m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeEngine },
new esriLicenseExtensionCode[] { });
//Do not make any call to ArcObjects after ShutDownApplication()
System.Drawing.Point p1 = new System.Drawing.Point(20, 20);
System.Drawing.Point p2 = new System.Drawing.Point(80, 80);
IPolyline pc = new PolylineClass();
pc.FromPoint = ConvertToIPoint(p1);
pc.ToPoint = ConvertToIPoint(p2);
IDisplay display = new SimpleDisplayClass();
IDisplayTransformation tran = display.DisplayTransformation;
Rectangle r = new Rectangle(0,0,100,100);
IEnvelope env = (pc as IGeometry).Envelope;
tran.Bounds = env;
tran.VisibleBounds = env;
tagRECT rect = new tagRECT();
rect.left = 0;
rect.right = 100;
rect.top = 0;
rect.bottom = 100;
tran.set_DeviceFrame(ref rect);
Bitmap bmp = new Bitmap(100, 100);
Graphics g = Graphics.FromImage(bmp);
g.Clear(Color.White);
display.StartDrawing(g.GetHdc().ToInt32(), (short)esriScreenCache.esriNoScreenCache);
ISimpleLineSymbol s = new SimpleLineSymbol();
s.Style = esriSimpleLineStyle.esriSLSSolid;
s.Width = 5;
IRgbColor c = new RgbColorClass();
c.Red = 255;
c.Blue = 0;
c.Green = 0;
s.Color = c;
display.SetSymbol(s as ISymbol);
display.DrawPolyline(pc as IPolyline);
display.FinishDrawing();
bmp.Save(@"c:\t.png",ImageFormat.Png);
g.ReleaseHdc();
m_AOLicenseInitializer.ShutdownApplication();
public static IPoint ConvertToIPoint(System.Drawing.Point pt)
IPoint p = new PointClass();
IZAware z = p as IZAware;
z.ZAware = true;
IMAware m = p as IMAware;
m.MAware = true;
p.X = pt.X;
p.Y = pt.Y;
p.Z = 0;
p.M = 0;
p.SpatialReference = GetSpatialReference();
return p;
public static IEnvelope ConvertToEnvelope(Rectangle bound)
IEnvelope env = new EnvelopeClass();
IZAware z = env as IZAware;
z.ZAware = true;
IMAware m = env as IMAware;
m.MAware = true;
env.XMin = bound.Left;
env.YMin = bound.Top;
env.Width = bound.Width;
env.Height = bound.Height;
env.ZMin = 0;
env.ZMax = 0;
env.MMax = 0;
env.MMin = 0;
env.SpatialReference = GetSpatialReference();
return env;
public static ISpatialReference GetSpatialReference()
ISpatialReference spatial_ref = null;
ISpatialReferenceFactory env = new SpatialReferenceEnvironmentClass();
//Beijing_1954_3_Degree_GK_CM_108E.prj(PCS)
string prj_string =
"PROJCS[\"Beijing_1954_3_Degree_GK_CM_108E\",GEOGCS[\"GCS_Beijing_1954\",DATUM[\"D_Beijing_1954\",SPHEROID[\"Krasovsky_1940\",6378245.0,298.3]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Gauss_Kruger\"],PARAMETER[\"False_Easting\",500000.0],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",108.0],PARAMETER[\"Scale_Factor\",1.0],PARAMETER[\"Latitude_Of_Origin\",0.0],UNIT[\"Meter\",1.0]]";
int read_bytes;
env.CreateESRISpatialReference(prj_string, out spatial_ref, out read_bytes);
double len = 5000 * 1000;
spatial_ref.SetFalseOriginAndUnits(-len, -len, 1000);
spatial_ref.SetZFalseOriginAndUnits(-len, 1000);
spatial_ref.SetMFalseOriginAndUnits(-len, 1000);
return spatial_ref;
