Create Feature Layer using ArcGIS API for Python
4681
03-03-2017 02:28 PM
ZacharyNeumann1
New Contributor III
I have a feature layer hosted in my organization that I want to turn into a new feature layer in my content, similar to this functionality:
I was messing around with some code:
base_comment_layer = gis.content.get('# acutal item ID goes here')
layer_properties={
'title':'Test_Comment_Layer',
'description':'This is a comment layer that is being used for testing purposes only',
'tags':'TPCM, Test, Python, Comment Layer'
gis.content.add(item_properties=layer_properties, data=base_comment_layer, folder='test_NF')
but that didn't seem to work, I was getting an error:
AttributeError: 'Item' object has no attribute 'replace'
This is obviously after longing on using the GIS() method.
Any adivice?
Thanks.
ZacharyNeumann1
New Contributor III
I solved my issue. For those interested:
layer_properties={
'tags':'TPCM, Test, Python, Comment Layer',
'type':'Feature Service',
'url':'URL to Feature Service'
gis.content.add(item_properties=layer_properties, data="URL to Feature Service", folder='test_NF')
ZacharyNeumann1
New Contributor III
layer_properties={
PhilippNagel1
New Contributor III
Thank you Zachary! Very helpful. This is not the most intuitive, and not covered very well in the docs.
MaximeCampeau
can you define more on how you get the item's ID ? Especially if you generate the results automatically from a script and you simply want to move that feature layer into another folder on your arcgis online profile?
