How to add Landsat 8 as a basemap layer?
1571
02-26-2017 07:21 PM
PitersonPaulgek
New Contributor III
We use ArcGIS Server 10.4, Javascript API 3.17
We need to add Landsat 8 as a basemap layer to the standard basemap Gallery.
app.basemapGallery = new BasemapGallery({
            showArcGISBasemaps: true,
            map: app.map
        }, "basemapGallery");
How to do it?
I know that it is ImageServer service.
Landsat8_PanSharpened (ImageServer)
Any help please!
PitersonPaulgek
New Contributor III
I have found how to do it. But how to show the copyright. I included "copyright" (copyright: "Sources: USGS",) as  BasemapLayer attribute - no effect
I found
The attribution information for the layer. NOTE: This property is only applicable to layers of type WebTiledLayer.
var landsatLayer = new BasemapLayer({
            url: "https://landsat2.arcgis.com/arcgis/rest/services/Landsat8_PanSharpened/ImageServer",
        var landsatBaseMap = new Basemap({
            layers: [landsatLayer],
            title: "Landsat 8",
            thumbnailUrl: "/Resources/Image/basemap7.png"
            map: app.map
        basemapGallery.startup();
        basemapGallery.on("load", function () {
            basemapGallery.add(landsatBaseMap);
PitersonPaulgek
New Contributor III
In addition to the copyright issue, we have an issue with printing.
The layer does not showed on the downloaded image.
Any help would be greatly appreciated!
SteveCole
One thing I see is that the service isn't cached, so maybe that's a reason you can't use it as a basemap? It's also published as an ImageServer as opposed to a MapServer. For comparison, here's the REST service endpoint for the ESRI Imagery basemap.
