Can I publish to 2 orgs from one Connect?
734
02-24-2017 08:46 AM
DougBrowning
MVP Esteemed Contributor
I am helping one of our other divisions get Survey123 going.  They have a totally separate AGO org account from us.  Can I mix and match publishing surveys to both accounts from the same pc/connect instance?  If i can switch logins before i publish I may be ok but wanted to check.
Also when upgrading to a new version of Connect do I have to uninstall the old version?  I am not sure I had to before but not it says there is already something installed.  I am just going from 1.8.7 to 1.10.
thanks
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
Yes you can switch logins between different accounts.  Note that surveys that have been published in one account are hidden while logged in as another user; all surveys that are on your computer are shown when you are logged out.
Yes, Survey123Connect requires uninstallation first when migrating between versions.
