4.2: Rotating MapView with MapImageLayer not aligned
1488
02-21-2017 06:52 PM
JordanKing3
New Contributor III
Hey all,
I've just noticed that if you rotate a MapView with an MapImageLayer on top, the MapImageLayer does not stay in sync with the views rotation. I.e. once you rotate off of 0 degrees, the MapImageLayer seems to rotate further each time and doesn't align with the view, util you go all the way back to 0 degrees.
This can be tested using the Javascript MapImageLayer sample: MapImageLayer - Toggle sublayer visibility | ArcGIS API for JavaScript 4.2
Just rotate the map.
Anyone else notice this? or have a workaround?
Cheers,
Jordan
Tags (1)
JordanKing3
New Contributor III
Hi All,
FYI - there is already a BUG report for this issue: BUG-000102157: MapImageLayer does not rotate properly when used wit..
Cheers,
Jordan
JordanKing3
New Contributor III
Hi All,
Cheers,
Jordan
JordanBaumgardner
Occasional Contributor III
*FacePalm* 3 days I've spent mucking around with projections ( I hate projections and just assumed it was that ) and arrrg it was my upgrade from  4.1 to 4.2. Thank you for your post.
