AnsweredAssumed Answered
How can I run a geoprocessing tool within a separate thread starting from arcobjects code / ArcMap extension ?
Question asked by u.egger on Feb 20, 2017
Latest reply on Feb 20, 2017 by Dan_Patterson
I have a method that involves among other operations the use of some geoprocessing tools.
Because this method takes some time and the input is not changed while working with the extension,
I want to have it run in a separate thread so that the main (UI) thread is kept available for the user and ArcMap won't freeze.
As soons as the Geoprocessor.Execute method is called, ArcMap crashes.
As I read in a forum on the internet that passing arcobjects to the separate thread I made sure I only pass strings as arguments.
Do I have to use Geoprocessur.ExecuteAsync ? It does not seem to be logical to me since I have to wait for the result until I can proceed with the next operation.
The workflow is approximately:
Foreach timestep
   Take corresponding raster dataset from geodatabase
      Run raster to polygon geoprocessing tool
      Run intersect geoprocessing tool to get intersection of Raster_as_polygon feature class from with another feature class
      Analyze the intersected feature class to obtain the results
Write results to file
Outcomes
