Unable to Change Style for OGC WFS Layer on ArcGIS Online
2977
02-17-2017 02:47 PM
dzahsh
New Contributor III
According to the documentation, Change Style reference—ArcGIS Online Help | ArcGIS , it seems that it should be possible to use Change Style in the ArcGIS Online map viewer to change the symbology of an externally hosted OGC WFS layer according to the layer's attribute values, but when I attempt to do this I am unable to change styles in this way. I am only able to change styles for all points at once ("Showing Location Only").
My process is:
From the My Content tab on ArcGIS Online, I select Add Item > From the Web, then,
   Type: WFS (OGC)
   URL: http://suite.opengeo.org/geoserver/medford/ows (which is a set of sample WFS layers hosted at opengeo.org)
   Title: Medford Schools
   Tags: test
   Layer: Medford, OR - Schools
Then, from the map's item page, I select Open in Map Viewer
In Map Viewer, I select Content and then I select the Change Style icon under the Medford Schools layer.
At this point, the Change Style menu is "Showing Location Only;"  I am only give the ability to change the symbology for all the points at once. I am not given the option to "Choose an attribute to show" such as is possible when I create a hosted feature layer.  The Medford Schools WFS layer has numerous type and numeric attribute fields that should be easily accessible to the Change Styles tool.
Is its actually possible to have full access to the Change Style tool with an externally hosted OGC WFS layer? If so, how? Or is this not supported yet?
KarstenRank
Occasional Contributor III
Hi Josh,
actually it is not possible.
See documentation on Change Style reference—ArcGIS Online Help | ArcGIS
I'm very also interested in this feature! Hope coming soon!
I have created an ArcGIS Idea https://community.esri.com/ideas/15433.
Cheers Karsten
