Editing the popup content of polygons in a sidepanel form
648
02-16-2017 03:00 AM
ChristianSailer2
Hello
I search for a JS template in the manner of "GeoForm", where you choose the polygon type from a template picker and add the attributes not in the pop-up window top of the feature/map area, but besides on side panel in a form such as GeoForm.
Does anyone have a solution or can cite a reference?
A big thank!
Christian
Tags (1)
RobertScheitlin__GISP
Christian,
   You would have to combine these three samples to get what you are after:
Template picker widget | ArcGIS API for JavaScript 3.19
Popup content in side panel | ArcGIS API for JavaScript 3.19
Using the attribute inspector | ArcGIS API for JavaScript 3.19
I have not seen where someone has done this before so there is not much more guidance available.
