OnScreen Widget place is Changing sometimes
1295
6
02-15-2017 08:47 PM
Naveen_KumarKairamkonda
 I placed Search widget(OnScreen) on the map, but sometimes when I reload the application widget's place is changing. Widget is appearing in some other place on the map.
When I open in the Google Chrome, Search widget is in other place.
When I open in the Internet Explorer, Search widget is in same place where I placed using Style Sheet.
What might be the reason?
Please suggest me.
Thanks in advance.
Regards,
Ibrahim
RobertScheitlin__GISP
Ibrahim,
   The only time I saw this happen was some time back when a person made a edit to the css that was throwing off the layout. Do you see this issue with a vanilla WAB App (i.e. not code/config changes at all)?
I am using Web appBuilder 2.0 version. Is this the version problem?
That is 3 minor versions behind and next Month it will be four behind. But I don't know if that is the issue for sure. What about the questions I asked in my previous post?
I read this article " Google Chrome 51.0.2704.79 was just released; it fixes the change that caused a blank screen for ArcGIS Online, Portal for ArcGIS, and applications built with the ArcGIS API for JavaScript ".
I'm using Google Chrome version 51.0.2704.63, But its fixed in Version 51.0.2704.79.
I will update to latest version of Chrome and will check the application.
Thanks Robert.
Related to the code, Just the "widget Id" got changed in config.json other than that nothing has changed.
If you have done no CSS or js code changes then starting the app again in the latest version will be no hassle at all for you.
