Collect GNSS metadata in Survey123?
2038
02-15-2017 06:38 PM
deleted-user-9zlChDJzM-SF
New Contributor III
Last year Collector came out with a release that allowed you to collect the metadata from an external GNSS receiver. I was wondering if that same workflow is possible through Survey123?
AdrianWelsh
MVP Honored Contributor
Shawn,
It looks like not yet from reading this post:
Survey123 for ArcGIS
If using external GNSS receivers, metadata such as 'Receiver', 'PDOP','HDOP','VDOP','Fix Type','Number of Satellites' or 'Fix time' will not be persisted in the geopoint. Storing this metadata from the external receiver is a feature that may be considered for upcoming releases.
It might be a good idea to suggest this idea at ArcGIS Ideas‌ or Issues · Esri/Survey123Community · GitHub
AdrianWelsh
Shawn,
AdamInglis1
I was hoping the Add GNSS Metadata Fields to a hosted feature service would work on a Survey123 hosted feature service.  The fields get added, but I wasn't able to populated them like I am in Collector, perhaps because the geopoint still isn't storing this data?
SharonUngerer_DNREC
New Contributor III
Check out the GNSS Values and Location Quality Expressions template on ArcGIS Survey123 Connect
I have not tried using a similar setup with an existing feature service....yet!
