Can you upgrade ArcGIS Server 10.2.1 directly to 10.5?
976
02-15-2017 12:44 PM
JanieGoddard
Occasional Contributor III
Can I upgrade my ArcGIS Server from 10.2.1 using a Web Adaptor but not Portal directly to ArcGIS Server 10.5?
If I upgrade my SQL Server 2008 R2 to SQL Server 2012 Service Pack 3, would this make this possible?
Janie
RebeccaStrauch__GISP
You should keep versions installed on the same machine at the same version.
re: Server, yes you should be able to upgrade from 10.2.2 to 10.5 Frequently asked upgrading questions—Installation Guides (10.5) | ArcGIS Enterprise
Web adaptors themselve do not upgrade...those need to be reinstalled/created, but fwiw, I have web adaptors from different AGS and Portal versions installed on the same IIS instance...with different names of course.
re: SQL  Upgrade an enterprise geodatabase in SQL Server—Help | ArcGIS Desktop
as posted by George Thompson  in another thread this morning https://community.esri.com/message/666573-re-105-upgrade-geodatabase-option-grayed-out
