estimateTileCacheSize (10.2.8) fails
910
02-10-2017 01:20 PM
by Anonymous User
Not applicable
estimateTileCacheSize (10.2.8) fails with the following error when pointed at a Hosted Tiled Map Service....
E/ArcGIS: No data tile ETag couldn't be retrieved
 com.esri.core.io.EsriServiceException: Not Found
 at com.esri.core.internal.io.handler.c.a(SourceFile:690)
 at com.esri.core.internal.io.handler.a.a(SourceFile:87)
 at com.esri.core.internal.tasks.ags.an.a(SourceFile:36)
 at com.esri.android.map.ags.ArcGISTiledMapServiceLayer.retrieveNoDataTileETag(SourceFile:570)
 at com.esri.android.map.ags.ArcGISTiledMapServiceLayer.initLayer(SourceFile:201)
 at com.esri.android.map.ags.ArcGISTiledMapServiceLayer$1.run(SourceFile:132)
 at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:423)
 at java.util.concurrent.FutureTask.run(FutureTask.java:237)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
 at java.lang.Thread.run(Thread.java:818)
I am wondering if there is anything specific in Hosted Tiled Map Services that would cause this issue?  The ExportTileCacheTask itself works fine however.  Just estimating the size fails.  Thoughts?
