AnsweredAssumed Answered
Pie-Chart tooltips not appearing when using Calcite Maps example
Question asked by rwnichols on Feb 10, 2017
Latest reply on Feb 10, 2017 by rwnichols
I am building an app based off of the Calcite maps example and have run into an issue.  When displaying a pie-chart in a popup it wont display the tooltip when hovering over the chart.  At first I thought that it was something that I had tweaked in my app that was causing it not to appear. However, I can replicate the same issue when I take the feature layer with popup from the multiple popup elements example found here: https://developers.arcgis.com/javascript/latest/sample-code/popup-multipleelements/index.html and put it in the Calcite maps example found here: https://developers.arcgis.com/javascript/latest/sample-code/frameworks-bootstrap/index.html.  The popup displays the requested data and chart, but when you hover over a wedge in the chart it doesn't show the category and amount in a tooltip as it should.  There is something in the Calcite maps template that is prohibiting it from displaying, possibly a CSS issue?
Outcomes
