AnsweredAssumed Answered
Geographic (Datum) Transformation Error 70116 in Mosaic Dataset
Question asked by p_griffith on Feb 8, 2017
Latest reply on Feb 9, 2017 by p_griffith
I've created a mosaic dataset in ArcGIS 10.3.1 with a spatial reference that uses the D_North_American_1983_HARN datum, as shown:
I then add raster datasets with a spatial reference that uses the D_NAD_1983_NSRS2007 datum, as shown:
I then select the NAD_1983_HARN_To_NAD_1983_NSRS2007_1 Geographic Transformation within the mosaic dataset default properties menu.
However, when I analyze the mosaic dataset, I get the following error (70116):
Am I using the incorrect geographic transformation? If so, which should I use?
(and do I need to use more than one? If so, I understand that I'll need to Project the original data)
Or is there something blazingly obvious that I'm missing here? I wouldn't think that the difference in units is an issue, but I'm happy to be wrong if that will fix the issue.
Thanks for any and all help you can provide!
Outcomes
