AnsweredAssumed Answered
Strange Popup Behavior with Multiple GP Tool Links
Question asked by lloydbronn on Feb 6, 2017
Latest reply on Feb 7, 2017 by rscheitlin
I'm working on a script with GP tools in a popup window. On click, the popup displays the lat/lon coordinates and two GP tool links. One of these is an ESRI sample tool that calculates population, the other generates a chart with a matplotlib script tool.
I'm getting some weird behavior with the inner HTML when I run the population tool. It says "calculating" Where it said "Three Week Chart," when  "Calculate Population" should be replaced with "calculating" instead.
If I click on another point, I get this:
I'm not sure how to fix this. Here is the relevant portion of my script.
var locationStr = {};
            var link = domConstruct.create("a",{
                "class": "action",
                "id": "statsLink",
                "innerHTML": "Three Week Chart", //text that appears in the popup for the link
                "href": "javascript: void(0);"
              }, query(".actionList", map.infoWindow.domNode)[0]);
          on(link, "click", function(){
            domAttr.set(dom.byId("statsLink"), "innerHTML", "Generating Chart...");
            window.gp_chart = new Geoprocessor("http://<ourserver>/arcgis/rest/services/Three_Week_Chart/GPServer/ThreeWeekChart");
               var feature = window.map.infoWindow.getSelectedFeature();
                var mp = webMercatorUtils.webMercatorToGeographic(feature.geometry);
             var x = mp.x.toFixed(3);
             var y = mp.y.toFixed(3);
                var lat,lon = "";
                lat = x.toString();
                lon = y.toString();
                locationStr = prompt("Enter Location Name", "Location", "Location");
              var taskParams = {
                "Latitude":lat,
                    "Longitude":lon,
                    "Location":locationStr
              window.gp_chart.execute(taskParams,gpChartResultAvailable,gpChartFailure);
                 function gpChartResultAvailable(results, messages){
            domAttr.set(dom.byId("statsLink"),"innerHTML", "Three Week Chart");
            //clear any existing features displayed in the popup
            window.map.infoWindow.clearFeatures();
               var chart = "Three Week Chart"
               var chartResult = chart.link("http://<ourserver>/Test_Charts/Three_Week_Chart_for_" + locationStr + ".png")
            //display the query results
            var content = "";
            if(results == 0){
              content = chartResult + "<br> for " + locationStr;
            }else{
              content = " Unable To Generate Chart";
            window.map.infoWindow.setContent(content);
          function gpChartFailure(error){
            var details = domConstruct.create("div", {
              "innerHTML": "Error: " + error
            }, query(".break", window.map.infoWindow.domNode)[0],"after" );
            console.error("Error occurred: ", error);
                "class": "action",
                "id": "statsLink",
                "innerHTML": "<br>Calculate Population", //text that appears in the popup for the link
          on(link, "click", calculatePopulation);
            window.gp = new Geoprocessor("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/GPServer/PopulationSummary");
            function calculatePopulation(evt){
            //display a message so user knows something is happening
            domAttr.set(dom.byId("statsLink"), "innerHTML", "Calculating...");
            //Get the feature associated with the displayed popup and use it as
            //input to the geoprocessing task. The geoprocessing task will calculate
            //population statistics for the area within the specified buffer distance.
            var param = new BufferParameters();
            param.geometries = [webMercatorUtils.webMercatorToGeographic(feature.geometry)];
               var distance = prompt("Enter Search Radius","Kilometers", 10);
               param.distances = [distance];
            //param.distances = [10]; //buffer distance
            param.unit = GeometryService.UNIT_KILOMETER;
            param.bufferSpatialReference = new SpatialReference({"wkid": 4326});
            param.outSpatialReference = new SpatialReference({"wkid": 102100});
            param.geodesic = true;
            esriConfig.defaults.geometryService.buffer(param, function(geometries){
              var graphic = new Graphic(geometries[0]);
              graphic.setSymbol(new SimpleFillSymbol().setColor(new Color([0,255,255,0.25])));
              window.map.graphics.add(graphic);
              //Use the buffered geometry as input to the GP task
              var featureSet = new FeatureSet();
              featureSet.geometryType = "esriGeometryPolygon";
              featureSet.features = [graphic];
              var taskParams = {
                "inputPoly": featureSet
              window.gp.execute(taskParams, gpPopResultAvailable, gpPopFailure);
          function gpPopResultAvailable(results, messages){
            domAttr.set(dom.byId("statsLink"),"innerHTML", "Calculate Population");
               var roundedPopulation = results[0].value.features[0].attributes.SUM;
            var content = "";
            if(results.length > 0){
              content = "Population = " + roundedPopulation.toFixed(0);
            }else{
              content = "No Results Found";
          function gpPopFailure(error){
              "innerHTML": "Population = " + error
Outcomes
